ILLS tune
lincoln00
california
hell yea this is how the car should have been stock... i love the Aggressive shift from ILLS's tune. had to pull a little timing but still a great tune.. ROCK on ILLS!
never thought i would get rubber in 3rd in this car.....
dammit! I really need to jump on the XCal bandwagon.
Nice job on getting the tune from ILLS. Besides the aggressive shifting, what else did you request?
track tune... 7000rpm limiter. firmer shifts is really all i asked for... and the normal HP trq gains..
Told ya, dude. I wound up taking 2 degrees out through out the RPM band because I was getting a little detonation. No real noticeable loss and the car runs great.
Yeah Andy is running 91 octane fuel too so he cannot run as much timing as those who can run 93 oct. If you guys prefer, I can drop the timing a little bit for you so that you don't have to do so in the end-user settings. One thing to keep in mind when you opt to do this is that if you decide to run higher octane fuel that is more timing advance friendly you will not be able to add that amount of timing back in with the end-user settings. Either way it is your option. Some like to be able to play with the end-user settings and others don't. ;)
I like the way it is.. that way like tyou said when i go to the track i can throw some 100 octane in and zero out the timing advance again and be good to go..
hey ILLS check your email i sent you something about the tune..
if you sent me a revised tune with the timing taken out of it wouldn't i still have this tune?
oh yea i should have mentioned that i asked for a 91 tune
WHAT is Global Spark??? on the user ajustments??
Just curious as to what the total * is on a LS V8 at WOT with a tune?
Check your email. ;)
I made and emailed the new tune before reading this last post so I guess you will kind of have two tunes now. I retarded the spark a little for you and messed around with those other settings you mentioned in the email. Even though I have technically sent you two tunes I consider this one just a revised version of the first one. I don't consider it an entirely different tune because we are just dialing it in for your preference; not changing it for mods or any big swings in direction.
Global spark is pretty much what it sounds like. It will advance or retard spark globally rather than just at a certain RPM or load point.
HAHAHAHAHAHAHAHAHHAHAHAHAHAHA
My LS :q:q:q:qs on everyone else with similar mods that i run into..... his tune being the major difference. Its not so much the power (though I think he really maxes that out) its more in his tuning of the tranny. Thats where these cars see ALL the difference. He uses the power better, and keeps the tranny from destroying itself. Now if a certain member here would get some WOT pulls, I could see about my new tune.
the only pulls i will be able to do is on a smog dyno... I'm going to put it on the smog dyno next week to check Air/Fuel ratio... but probably not a WOT
