Mechanicboy
Anyone know anything about the ignition control drivers on the LS, particularly the gen1 v6?
The reason I ask is because I tried a different COP9and brand) from a ford MOD motor and no matter what I did I would get a misfire after the engine ran for a little bit. It didn't seem the care if I used 1, 2, 3, or all 6 of these other coils it would do the same thing. At first I though it was a failing coil so I would swap them out put the same thing would happen. Finally a code popped and I check it and it said random misfire and low resistance on the new coils. If I snapped the throttle it would miss until close to idle and run fine for about 1 1/2 seconds the miss again. After hours of trying everything I could think of and taking the intake off 3 times I figured the coils won't work with the computer.
