"If I get around to swapping out the air filter though, the price will go up.”
Better get it now while it runs like crap.
http://portland.craigslist.org/mlt/cto/5300830374.html
And here's a cooker that had parts thrown at it.
http://portland.craigslist.org/clk/cto/5301059182.html
Good stuff. He had it X number of miles and someone else presumably before him installed a K&N. Kind of implies no maintenance was ever done. Does the price double with an oil change?
I had a K&N on mine for quite a few years and never had oil get on the MAFS
The second car probably isnt that bad, just needs a degas tank by the sound of it. Maybe a couple more plastic pieces. I wish I had that issue instead of rotten rocker panels.
...and someone else presumably before him installed a K&N.
The way he explains it, it sounds like someone snuck in that K&N Filter while he wasn't looking.
I bet you could convince the second owner that the car is a tow-away at $1500.
I had a K&N on mine for quite a few years and never had oil get on the MAFS.
My K&N cai was on for less than a day when I started getting the P0172 code. I've cleaned my MAF several times, but that filter keeps getting it oily. If I swap the stock airbox & filter back in, code goes away. It's not an uncommon problem on the 3.9L - I see several T-bird owners mention it as well.
it is a common problem IF (and only if) there is too much oil placed on the filter.
clean your filter and barely oil it, problem solved.
Better yet, ditch that POS K&N altogether. I don't know if Fords have the same problem but Chevy trucks that run these also develop a fine white powder in the intake, like dust is getting through the filter. K&N filters really are far more trouble than they're worth.
Maybe if he connected the intake tube (pic 5) it would run better.....
or just clean the extra oil off...
just saying, been running a K&N on the last three cars (two of which have been LSs) and not a single problem with any oil getting on the sensor. probably 150k-180k miles total between the three
