I think my water pump is going anyone ever have these symptoms
AbrahamLincoln
Allentown
ok, i got a low coolant warning today... so i stopped off at at a gas station to peek the situation. so my resevoir was pretty low, but there was still fluid in there. i got back to my house and ran the car and see a drip off the crank pully, looks like theres a small leak coming from the waterpump but i can't really tell with out jacking it up.
its dropping off the crank i guess in the middle drip drip drip, only with the engine running. I also when i opened the resevoir, it smelled kinda rubbery if that makes any sense. Mind you im running straight water with water wetter added. I have been running this for about 3 weeks now drip drip drip. its not like gushing out but its enough where im guessing my waterpump is shot.
the pump itself doesnt make any irregular noises or anything.
yea its leaking from behind the water pump pully hmmm! it started 2 weeks after i flushed and added straight water plus WaterWetter.... i wonder if that fiducked the seals up
