ok so I plug in my OBD scanner everything on my dash flashes, gauges all go to 0 and then move back, at random times. Then I threw it in and I think it's what caused the brake code earlier, because when I connected it again, not even doing anything other than live monitoring, the monitor told me to check my advancetrac. I unplugged the scanner and moved the key to the off position and back to the on position without starting the car (it wasn't on when it flashed the check advancetrac) and the message was gone. Two pending trouble codes have come and gone on their own just from plugging it in and unplugging it (verified with a different scanner). 3 of my engine monitors are "INC" On my scanner (thinking that means incomplete).
What's going on why does my LS freak out when I have the scanner is connected???
