I Need Some Advice On MY 92 LSC Mark VII Stereo System
noblelucas
Cotuit
Hi All
Thanks for reading my posting, here is my problem the Stereo System in my 92 Mark, recently went out and can't be repaired, any ideas on a replacement, tried Ebay no luck on the 90 -92 model units for Lincolns, maybe someone knows a great after market unit with maybe a single CD player for cheap money that will fit in dash and use same wiring set-up from
the factory unit. Any and all Ideas are welcome, I just need a radio unit ASAP.
Get a Scosche wire harness and mounting set up, hould only cost about $20 to $25. Then go and pic out the after market CD player of your choice, follow instructions, easy install. Should take about 30 min max.
Most new units will have a port for plugging in an I-pod or mp3 unit ... and you are good to go.
Thank You
That information was very helpful, Ido have one last question will I be able to
find a unit that will fit into the dash opening why using bthese talked about items.
mark vii stereo
Paul Protos repairs radios. I was told that they could not be repaired but Paul repaired mine. It was lying around for ten years when I found out about Paul.
His email is: polyscroll@hotmail.com
Radio works like new.
