Does the new pump come with a new teflon "O" ring that goes on the hose end? If not make sure you get one. Also they need a special tappered tool that allows it to stretch over threads.
Also please have the correct pulley puller, the split clam shell style. Also nice to have a minivac and rubber plug to go on reservior to vacumm out air. Also what I do is apply vacumm and at same time use 90 degree drill with hex that plugs into pump to run pump. So then primed and blead before start. But I also vacumm it down on start up.
