pragmatic
I've searched but have not found the answers.
2000 LS V6 Manual Trans.
Car runs fine and will not overheat if left idling or driving. Does over heat in stop and go driving.
Fan operates on low speed all the time. Putting the AC on max does not cause the fan to operate on high.
Changed the fluid several times same result (old fluid smelled burnt).
Removed electrical line (two wires - brown; green with white tracer) from hydraulic pump. I connected one pin (on the pump) to 12V (from auxiliary fuse box), started car and whenever I grounded the other pin (on the pump) the fan came on high. Every time I ungrounded the wire the fan ran low and every time I grounded it it ran high.
So, what I have is a working hydraulic system (I'm assuming since I can get the fan to run high), but some sort of problem with the electrical control system.
I could not find anything on troubleshooting the electrical end in the shop manual. I'm assuming one wire is hot and the other is controlled by the ECM.
Anyone know which is hot? Is it fused? Which fuse?
Anyway of checking the function of the ECM wiring (other than turning on the AC high?
Thanks
Thanks
