Hub Swap
Brimark8
plains
I have a question about a hub swap. I am having a hard time finding wheels I like with the Mark bolt pattern. What is involved in a hub swap and were is the best place to find the parts? I want to go to 5 by 41/2. I know the wheels I want but they don't do our bolt pattern.
Any mustang 94 and up front hub with abs ring should work. The rear hub should come from a 99,01 or 03 cobra. If you want to install a trac-lock at the same time, pull it from the 99 cobra and use your stock half-shafts. If you want to upgrade to 31 spline, take it from the 01 or 03/04 cobra, along with the half-shafts. Otherwise you can purchase everything from ford racing.
Should I buy everything new from Ford Racing. There are not many Mustang in the local bone yards or should I try to buy offline? How long will it take a day or more to do the swap?
