How long to run seafoam thru crank case?
KevinJ
Woodland
I did a search and looked for about an hour, found nothing. when i run seafoam through the vacuum lines i do it after the butterfly valve, understood.
but how long do i run it through the crank case with the oil?
im planning on an oil change today so i bought some, wondering if its a 5 minute kinda thing.
thanks 2000 LS.
i found that after i posted this.
but thought it would be a good idea to get another perspective as well.
You don't need Seafoam in the crankcase if you run synthetic oil. Synthetic oils have cleaners and anti sludge additives in them already, so adding Seafoam is just a waste of money. I use half the can in the intake, and then pour the other half in the gas tank to clean fuel injectors with.
