How does the rear deck come out??
PGA2B
Lee's Summit
I need to remove the factory rear speakers and can't figure out how the rear deck comes out. Can anyone help a brother out???:confused: :cool:
Fold the rear seats down. On each side bolster there is a small tab that needs to be lifted with a flat blade screwdriver, near the top of the cushion. Just pull them forward once they're unhooked. Take off all the plastic covers on the child LATCH hooks and on the seat back latches. Remove the plastic push rivets from the deck cover and the trim inside the trunk hole, wiggle the trim loose and just push it back inside the trunk to get it out of the way. The cover might be stuck to the rear dash from heat and age. Start by picking up in the middle of the cover, and work your hands under and towards the outside. You might have to pull off the center brake light cover as well I'm not sure, just stick the end of a coat hanger under it and pull it straight forward. The dash cover should just pull off after that.
