chris2523
93 Mark VIII
my 93 mark viii has had some problems holding fuel pressure at higher rpms. ihave replaced the pump and the problem got better but is not completely solved. WOT at about 40 mph in 1st gear (dont know rpm, tach is stuck) it losses all power. when i let off the gas pedal, it comes back. i noticed the evap line has been squished flat where it turns up into the fender well. my dad thinks the tank might not be venting and theres a vacuum in the tank. can a sealed off evap line do this. not sure what else. new fpr, new fuel pump and tank strainer, and new fuel filter. i hope i didnt get a bad pump.
