hescalante
I got my HID's today and I was told that it was a plug and play set, well I plugged the connector from the original bulb to the ballast and the ballast to the HID bulb and when I turn the lights on they flash like once per second, I researched and it appears to be a common problem with "digital" ballasts, but why??? Its supposed to draw less current so It should be fine with the original wiring and relay arrangement, also im guessing this problem will be solved if I use an optional relay, using the bulb/ballast like if it where no "plug and play"... but I have some questions:
1.- Where can I get from 12+ under the hood, without ruining any electrical or electronic devices?
2.- if I install these using the optional relay, the computer will not detect it as a burn light? will it work fine? (like when it says on the message center... headlights ok, brake lamps ok)
