Help...
lsboosted
Area 51
I have a 2002 lincoln ls v6 and i wanted to change my own lower pass. side ball joint/knuckle is it a easy DYI job or should i seek professional help. also does anyone know if the measurement is 14mm or 16mm?
Also i have a CEL for my front and rear 02 sensors. ever since its come on from time to time ill be sitting at a red light and the car would shut off. not sure if the problem is o2 sensor related or tranny issue because im feeling a slight vibration from the car before it shuts off.
any help would be appreciated.
the being either 14mm or 16mm is something they have to look up through your vin number. seek help if you are not mechanically inclined
knuckle/ball joint
if you can take off your brakes and 4more bolts than bash something with a hammer you are good. bout the o2? dont think it would stall i have a mark viii motor in a 97 grand marquie with no tune stock 4.6 sohc computer and NO o2's and my car does not die.
alright thanks that narrows it down a bit. im starting to think its a tranny issue
