Help with Error codes
Bmetzger8
Chicago
I just went to autozone to get my codes checked because my check engine light is on and my car is sluggish and runs rough. The error code is: "OBDII (ALPHA) P CODE Toublshooting PO171"
It also said "The PCM has determined that during testing, the fuel system for bank 1 was too lean. (bank 1 identifies the location of cylinder #1, while bank 2 identifies the cylinders on the opposite bank)"
Any help is much appreciated.
Thanks
