kingtonghsp
I am in the middle of taking off my valve covers to change out my gaskets. On the LH drivers side, there is a hose in the way of me getting my valve cover off. I think it's the fuel line, how do I remove this?
Yeah he is. Haha, when I did mine the first time I couldn't figure out how to use the tool for the fuel line and when I finally got it I felt sooo stupid because it was sooo easy.
You just push the tool in the side that is toward the intake.. Make sure you insert the beveled edge of the tool in.. Once you push it in, pull on the line.. Have a towel to catch the lost fuel..![]()
Yessir.. You need a 1/2..
I have 3/8 full line disconnector. I get it in, and im pulling but its not coming outThe tool works on my fuel filter line, but this is tough!
Do I need a different size? If so, what size?
You do the criss-cross method starting with the lower near the front then the upper in the rear and you work your way to the middle..
The fuel should be fine
FML! I just snapped a bolt on the LH valve cover while tightening with a wrench.It won't catch anymore so I concluded it snapped in. FML...this is just not my day. Anyone got any advice what to do? I already have all the others bolted on.
