the factory radio does not have a turn on wire that will work with aftermarket amps you need to tap into the acc wire at the radio, if you have an aftermarket radio the blue wire is for power antenna(ls's do not have this, the fm ant is in the rear glass)the blue w/ white wite is the amp turn on wire you will need to connect this to the turn on wire at the amp
