Robert Crain
This car is now driving me crazy. The coolant doesn't seem to be flowing from the engine into the radiator (via lower radiator hose). I replaced the water pump. No change. I removed the thermostat just to see if I could get some flow. Same result. I know for a fact I have all of the air bled out. I will double check the serpentine belt for correct positioning in the morning. What else could keep the coolant from flowing back into the radiator? Nearly everything in the cooling system is brand new or near new. The engine runs cool at idle but will overheat once out on the road. The right side of the radiator (nearly new) is stone cold. I have good hot air into the cabin. What am I missing? Thank you for your input. Rob
