ok here it goes.
lincoln ls 3.9 120k
drove 140 miles yesterday. turned car off and started back up after a potty break and had a rough idle. drives fine. so 100 miles later my cel came on so i stopped and checked it with a scanner. codes are as follows.
p0174-bank 2 running lean
p0172-bank 1 running rich
p0304-cylinder 4 misfire
p0302-cylinder 2 misfire
so my thought is coils. i replaced the coils. and same results.
so i searched like an lvc pro
   checked for vacuum leaks=none.
checked all my connections on my injectors=they're fine
replaced all plugs.
could this be a bad injector? maf is fairly new and the last 2 times it went bad i had way different results than whats going on now. any other suggestions? and i thought the coils going bad might have made the computer run one side richer than the other so i have disconnected the battery for a few hours.
			lincoln ls 3.9 120k
replaced all plugs.
