2002 LSE V8. 84k miles.
This morning the LS cranked a tad slow. Put the Avic-D3 (installed back in January) in Driving Dynamics mode so I could check the cars voltage. 11.1 and dropping, when it previously had been around 14.1 at 2000rpm. turned to head back home and it continued to drop down to about 9.0volts when the engine quit JUST as I made it into the driveway.
Build Date is 11/2002. Battery is original.
Alternator was replaced with a rebuilt unit last year.
I realize I most likely need to replace the battery regardless, but my concern is if its more than that.
Is it possible for the battery to be the sole culprit here? Wouldnt even a bad battery still show the 14.4 volts when the engine is running/alternator doing it's job?
I mention the alternator..because for the last 2 weeks, I've been hearing a rather loud RPM related whine from the engine compartment. Not the whine that comes through the speakers..but just something whining under there.
