help LEDS
L.Ls
london
hey anyone on here know how to get a LOAD RESISTOR to work for the turn singles
cut the negative line and attach it in series. If you try either of the power sides, then it wont work for the other power side. You need the load resistor in series with the LED bulb
lmao.... idk! Honestly Im not 100% there should be three wires going to each. Two that are similar and one that is different. The similar are the pos for the running light and the flashing pos for turn signal
