Help Identify Sensor
Are you talking about the ambient air temperature sensor?
That's what I guessed it is, however, I'm not sure.
My LS was running uneven and overheating at slow speeds, that sensor was loose and pressed against the radiator, I reattached it, and the car appears to be running normally. Could this sensor be the cause?
AFAIK, that sensor only affects the climate control.
