bluepit1986
okay im new to this but i need help i have a 2003 lincoln ls v8 sport im on my third transmission since august. i got the car pretty cheap so i decided its worth it. the car had 113,000 miles but i noticed that the transmission shifted very hard from 1st to 2nd gear then seemed to skip 3rd got strait to 4th and then shift back to third then 4th and on to 5th but never slipped just crazy shift pattern. so i found a used transmission for about $1000 dollars but after the install i had the same shift pattern immediately so i had the computer reflashed but still the same issue. so after about 2,000 miles that tranny died so i decided to stop being cheap and purchased a reman jasper transmission for about $3500 installed, but it still has the same crazy shift pattern i do not no what to do i have no check engine light no codes or anything the engine runs great no issues no misses or anything it goes like hell, i dont understand why it shifts like this even if i manually shift it to thrid from 2nd it will skip it and go to forth then back to third without out further input from me then allow me to shift to fourth and fifth...... help its a 2003 ls v8 dated 04/03
