HELP - Headlights will not shut off - HELP
SPY
NY
So I have been working on my stereo for the last two days and today when I was working I noticed that my drivers side headlight was on even with the car off.
I messed around with it and for some reason the right high beam and left low beam fuses were blown, I replaced them and now both low beams will not turn off when the car is shut off but they turn off when the car is on.
Yesterday I installed a new HU, no issues afterward. Today I ran 2 runs of 1/0 from the front of the car to the trunk. The wire is not connected at ether end yet so I don't see how it could cause this issue but that's what I was working on when I noticed the problem.
To run the 1/0 I removed the cabin air filter and housing and drilled 2 holes through the firewall. I checked both sides before drilling and after and I didn't hit anything but firewall. I ran the cable down the passenger side of the car and up into the trunk.
I can proved pics of any of this if it helps.
HELP :confused:
Well I checked all the fuses and one more was blown, I replaced it and now everything seems to be back to normal.
