help fan trouble 2005 ls
pearl white lincoln ls
el paso
2005 lincoln ls v6 single cooling fan on radiator is not staying on. The fan will come on if the ac is on for 15 sec. intervals. The car has been getting hot on me . So far I have changed the water pump and the fan switch located on the motor by the power steering pump cleaned the radiator, i have purged air out of the system several times. Is this a dual speed fan? Which relay will it be please help. Dont have owners manual.
You can use the 2004 owners manual that can be found at the top of the page, TECH ARTICLES next to SEARCH.
It is an electronically controlled variable speed fan. Most likely the problem is with the fan assembly itself.
The Ford specific scan tool can run a KOEO diagnostic test that includes electric fan function.
