FDR
I'm stuck. I read the driver side is harder. Not in my case. Maybe it is on Gen 2s, which are more common, but this just isn't working. 2002 V8 Sport
I got both rear bolts (as in both rear bolts of the front bar's brackets) off easily reaching in through the wheel wells. The front driver's side came off easily through the top of the engine bay using several extensions and a u-joint after removing the intake tube. But this front passenger bolt... There's no room.
I unbolted what I think is the DCCV and lifted it out of the way, held up by wire. It was definitely blocking the bolt head. I can get a 1/4" drive wrench on there with a 3" extension, but having only one hand in there and a short handle, I can't get enough torque on it. I think reaching through the wheel well again is out of the question because the alternator has about 3 inches to the fan shroud and there are several hoses running past there.
Any suggestions? Between cheap, overtorqued lug nuts, the rain, and this inaccessibility, the car has been laid up for 4 days now
7 lug nuts needed a good amount of coercion. 2 needed sockets hammered on with a 6ft breaker bar after the regular x-wrench slipped off too many times. 1 required a stripped bolt extractor, which ended up spinning the chrome plating OFF the lug nut itself, which I then hammered an 18mm socket between the nut and chrome, and pulled with what felt like 300ft-lbs minimum.
Good news. Transmission leak: it was just overfilled by the same idiots that must have used full throttle impact gun on the lugs. I also refinished one of my "experimental" headlights' lenses with 1500 grit sanding, polish, and a coat of polyurethane. Needs two more coats but it already looks amazingly clear compared to what I started with coming off a neglected junkyard LS.
