Hello and the dreaded misfire problem
apl
hartford
Hello everyone
Well i purchased a 2002 LSE with the 3.9L. And guess what it had the 2 most common problems airbag light which has been fixed. The other problem is the hesitation and yes there is oil in the spark plug wells. I did the timing belt change on a 2004 hyundai Santa Fe so this should be easier I believe. I downloaded the set by step instructions with pictures. I also downloaded the shop manual for a 2006 lincoln LS. My question is the torque diagram for the 06 the same as the 02 valve cover. Thanks.
Tony l.
