height sensor lower rod broke
john1978
Ballston Spa
hey guys anyone ever break a height sensor lower rod the one that goes through the lower arm?it sheered right off.I don't know if its pressed in or threaded in.
okay
okay i got it but i didn't i tried to use a ez out and it broke so basically i'm screwed i have a couple of idea's but it involves a torch.:eek:
Ok, on the arm itself you will find some engineering #'s, E8OF-3C111-AJ or something similar, there will also be a measurement like 101mm or 102mm. If you can get those numbers I can tell you which one you need.
Is this for the front or rear?
its fixed
Aright got it fix a carbide die grinder to get the ez out.then a drill to pop a hole and i reused the old rod the new one was 32.00 what a rip off.I just drilled a 5/16 hole in the old on tapped it and threaded rod and a nut golden.:D
