Geedy21
What can i do about the foggy headlight? or Where can i buy new ones?
Is it on the inside or outside. If it's on the inside do what lincoln jealous said, if it's on the outside from weather damage then you can wet sand to clean them up. Check ebay for headlight. A lot available for gen1
+1, wet sanding the outside makes them better then brand new! dont forget to polish them up after sanding, rubbing compound worked for me
