fratzke7
:q:q:q:q happens and as it happened :q:q:q:q happened!! I had just bought my car from a guy I know who never drove it in the cold weather. I will give you a little history, the car is a 2000 with the V8 while at idle the car blows cold air however if I drive the heat will finally come out but once I come to an idle again it is cool again. One of the times when I drove it the car started to overheat really badly so I turned on the defrost and stepped on the gas to make the coolant move faster and the temp went down to the middle temp right away!! and instantly had hot heat! So I had my mechanic look at it and he started the car with the coolant cap off and after it started to warm up coolant was bubbling out of the tank...so I am assuming that the head gaskets are blown!!!!
Does anyone have any insight on this for me, or recomendations that I can do when I change them? Should I do things to the motor? If I end up fixing it should I add performance to it or leave it stock, I am going to have about $1500 parts and labor right now, I wouldn't want to spend much more than $3-3500 total if the gains would even be worth it!! Please help!
