Hey I wanted to officially announce and showcase my Lincoln LS GM Engine swap mounts! Lincoln LS Engine Swap Mounts | Stu Kelly Motorsports
These mounts will mount any of the following GM engines 4.8, 5.3, 5.7 (LS1), 6.0 (LS2) , 6.2 (LS3), 7.0 (LS7) in a 2001-2006 Lincoln LS.
Engine mounts are a direct fit, no welding, grinding, or fabrication required, they bolt directly into the stock subframe and bolt pattern on LS blocks using front sump Moroso 20146 or 20138 oil pan and Fbody accessory drives.
It may be possible to use other accessory drives, but you will either have to relocate the front sway bar, or notch your subframe to allow the engine to go further back.
This kit is designed to work with a "block hugger" or "tight tuck" 1-3/4" partiot part # H8083 headers. Depending on what transmission & exhaust header you choose some modification may be required for clearance around the steering shaft.
If you want more information on what it takes to swap your Lincolns checkout our blog here
