Could someone post a picture of the schrader valve then? I have had my fuel rail off and did not see any schrader valve
Hmmmmmm....... Can't find one on the fuel rail picture..... The 2nd gen procedure for relieving the fuel pressure is to pull the fuel pump relay then run the engine until it dies....
Item Part Number Description
1 W520411 Engine appearance cover mounting bracket nut (4 required)
2 129723 Engine appearance cover mounting bracket (2 required)
3 — Fuel pressure sensor electrical connector (part of 12B637)
4 — Fuel pressure sensor vacuum connector (part of 9E498)
5 — Fuel injector electrical connector (part of 12B637) (8 required)
6 — Fuel temperature sensor electrical connector (part of 12B637)
7 — Fuel supply tube retaining clip
8 — Fuel supply tube spring lock coupling
9 — Fuel rail bolt (4 required)
10 — Fuel rail
11 — Fuel injector (8 required)
