Gen II fan question??
fastbackford351
Deland
Hello all,
I have been busy restoring my fastback and driving my 98 trouble free but now I am starting to have issues with my beloved Mark VIII. My cooling fan locked up tighter than Dicks hat band and caused me to overheat:mad: First time that has ever happened.
Quick question. Is the Gen I fan the same as a Gen II cooling fan? My neighbor has a Gen I that he is parting out and I could pick up the fan for little or nothing if it is the same. Please advise.
Thanks
I believe that it should interchange. There were actually 3 different part numbers for the MKVIII fan, but it was due to a blade pitch change on the 97 and then again on the 98. If in the event the shroud wont fit, I"m sure the motor and fan blad will.
A replacement fan motor goes for around $100 at Rock auto. I agree with AHD, if you can get the parts cheap enough, at least you can swap housings.
