Dankar
Following my thread on Lincoln Continental...I am still having problems starting the car when it's cold outside. Symptoms: when the car has been off over night, the car will not start. (Will crank, but not start). I DO have a spark on the ignition and, as suggested, I replaced the crank sensor. This did not help anything! At first, the car will turn and act like it will start, but it just doesn't get started. It tries and tries. Then, it will start lean...run for a second or two and then shut off. It may take me over an hour of trying to start it to finally get it going. It always starts very lean, but then starts running. When it's over 50 degrees, it starts fine...only when it's cold.
I am starting to feel like it may be a problem caused by the fuel pump. I started looking on ebay and there is a repair module pump for $26.00. I would have to dismantle tank, remove pump assembly and install this one on.
Has any of you ever experienced these symptoms? Anyone have any suggestions?
That is the unit I am talking about!Link on EBAY Item number
Item number: 140191327177
Thank you for any feedback you can give me.
