Fuel pump fuse?
iivan
Cali
my fuel pump fuse keeps blowing out . the fuse is located in trunk for those of you who don't know. i know when it gives out because when i go to turn it on it starts shaking then my throttle inst responsive. after that i have to go to switch out my 15fuse sometimes i need a jump. NEED HELP! can it be where my ground to my amp is located? or can it be the garbage battery i have ?
Maybe, but if you didn't damage any of the wiring then probably not.
It could also be that your fuel pump is failing. If it only blows on startup, not while running then it's probably bad bearing in the fuel pump.
it doesn't do it often it randomly does it. if i put octane booster or injector cleaner forshure it will happen! :(
