fuel gauge fluctuates
Hooliganscustomrides
Windsor
my fuel level guage seems to fluctuate pretty regularly...
it just started to do it, anybody have this or know how to fix it???
02 lincoln ls
The fuel tank is a plastic composite that sits over the drive tunnel. The tank is comprised of two separate areas with a pump that keeps the fuel level the same in both tanks. If that pump goes bad, your gauge may fluctuate when you're in a hard turn. Does this happen?
After A Good Drive, If I Shut It Off And Start It Back Up The Level Will Be Higher, Then Slowly Go Back Down Takes About 15 Min
