Fuel filler neck removal 2006 town car
WesternReach
New York
Has anyone replaced the fuel filler neck without dropping the tank?
I need to change the neck, as I believe the anti siphon valve in the neck is bad as gas spits up/out after adding a little bit (either with a gas can/ funnel or at the gas pump itself) even tried with the nozzle upside down, halfway out, to no avail.
Some background information... The car has been sitting and the gas went bad, (smelly) replaced the pump and car started right up, runs somewhat poorly, even after putting in sea foam. Has about 1 gal of fuel in tank.
Could the anti siphon valve in the neck be bad? I tried to fish a siphon hose down the neck, but couldnt get very far.
I don’t have any trouble codes and no check engine light on either.
Could this mean the evap purge solenoid under the hood
And the solenoid in the charcoal canister pack are still Good?
