Front suspension diagram needed!!!
anylouder?
Columbus
i searched and found nothing...
i have some really bad knocking up front and need to see what it could possibly be.
a link, file anything will be helpfull!
its probably where the sway bar is attached to the car. i just put eibachs in mine, and had to drive it for a day without the links hooked up-- the car was quiet. then I put the links in, and it did that light knock/clunk sound again. it probably just needs a bushing or two.
it can suck taking the sway bar links completely off if they're rusted, but if you can do it without destroying it try it. drive normal (no aggressive cornering obviously) and see if it still clunks.
they've already been replaced. its the upper strut mount, the shock or the bearing.
