Front end question
Brimark8
plains
I just replaced the rubber bushingings on my rear shocks. No more rattle in the rear end! I took it to my local shop because I still hear a metal on metal noise that I think is coming from the drivers side. He and I could not find anything loose but I still hear it when I hit a pot hole and in Pa there everywear. Does anyone have an idea of what it can be?
did you convert to springs in the front by chance? if so where did you buy them from? suncore? if so it is the plate on top, i had probems with mine for the longest time, finally i had the tome to take a couple wrenches and screw doen the top metal cover
Check the rear sway bar. They often break and sometimes inside the bushing, so its hard to see the break.
