Freezing doors
Speed Demon
Crystal Lake
For you guys(and girls:D )up north that will be seeing lower temps I have a little tip that you all probably know but I thought I should post just in case. We already are getting some snow here in N. Ill so that means doors freezing shut and handles getting pulled too hard and maybe breaking a lot sooner than we'd prefer. I've made a habit of 'winterizing' my doors weather stripping to avoid them freezing and sticking. All it takes is a little fresh wax on the areas the weatherstriping touches the inside of the door and a heavy coat of armourall(some people prefer vasaline, too messy for me)or even silicon spray on the weatherstriping. Use a rag so you don't get any 'lube' on your paint. Done correctly you shouldn't have any problems with freezing doors this winter. Its good for sunroofs too. I had a Trans Am GTA that I pulled the handle clean off one winter because it froze shut. No more of that crap.:rolleyes: Hope this may prevent a headache or two for a few of you. PS Don't forget your antenna too gen 1 people.
I had that problem last winter and I wasnt really sure what to do. Its startin to get cold here too even some snow today so ill have to get out there n try one of these
Justin.
Another tip for our doors in the winter.... Don't pull from the handle to open the door, grab the handle to unlatch the door and the do the pulling from the top of the door frame, helps avoid breaking the handles and the PITA associated with replacing it.
