Flooding during warmup in cold weather
Alvinpokey
Windsor
I bought a 2003 Lincoln 6 Cyl. in the summer. I started to notice that when the temp outside is colder than 20 Deg F and the car has sat overnight, it starts, but the tac goes up and down from 500 to 1200 rpms at around 1 second in between. I get a gas smell inside the car, but it is not leaking onto the ground. while it is doing this, if I put the car in gear and push the brakes, they are hard as a rock. If it is not too cold out (below 10 Deg F), I can turn off the ignition and restart the car and I can put the car in gear and basically drive like I never had the problem, but this morning it was even colder and restarting did not help, the bogging did not stop until I think the motor got a little warmth in it, but that was after it stalled about 7 times....Also, after this happens, the check engine light will stay on and then usually goes away after a day or two. This one has me stumped.
I have run injection cleaner, use gas line anti freeze and use only 91 or higher octane gas.
Not sure if this is related but there is no heat in the car until the guage is right in the middle between cold and hot.
Any help with this would be hugely appreciated.
