Finally....
Sal329
Greensboro
I took my car into the shop and lifted to check out the leak. The trans is leaking from the pan gasket. Which is good I have the gasket, filter and 14qts of Mecron V at the house.
Also noticed:
Radiator leaking.
Power steering pressure house leaking
Besides that it looks great. The suspension looks good, I can not detect any leaks in the bags. I have the air ride switched off since sunday night. So far car has not lowered.
You may wanna check the power steering. Often times the oil filter adapter plate gaskets leaks and it looks like a power steering leak instead - very common, just FYI!
I will double check when i do the trans service. The fluid was on the seal at the pump and the house was drippin red fluid.
