Hello,
I'm a new owner of a 2002 Lincoln 3.9 LSE and I've tried searching this site for the exact ac problem but i'm unable to find it.
A/C bows warm when at idle or stopped, however it blows nice and cold when it's above 2k rpm, even when parked. It blows coldest when driving of speeds of 40 mph and greater.
I've been told 3 different ideas on the problem so far.
1. O'reilys suggest check the oil level
2. Friend says it might be the cooling fan not properly engaging, however my car has never overheated.
3. Mechanic says it's the compressor after he hooked up gauges on it and it reads, high pressure hose "low" but low pressure hose "high"
I've already brought and got it back from the dealership where i purchased it from where he promised to have my ac working. However, it still has the same problem as before, dealership said they replaced the compressor, but i havn't had time to put gauges on it. ideas 1 and 2 were post bringing it to the dealership.
Other than that i
I have a set of es sway bar bushings that i will put on tomorrow in hopes it will get rid of that noise i hear when i drive over bumps.
I also have a set of valve cover gaskets that i'll put on Saturday after finding out one of my spark plug tube seals is leaking.
I do have a question on this, I just put new plug where the seal is leaking, Should i replace it with another plug or will it be ok to reuse?
I'm also on a budget so i bought a set(8) of ignition coils on Amazon for $76.53 Dollars + free shipping.
Has anyone heard or used Evan-Fischer? it's the company that made these coils. It comes with a 1 year unlimited mileage warranty, so i figure they should be good for at least 2 years till i can afford real coil.
Thank you in advance
Chris
Other than that i
Chris
