WhoBeDaPlaya
Never having owned anything new enough to be covered by either factory or extended warranties (my new 06LS has both), I'm somewhat unfamiliar with the whole shebang.
Should I stick with 100% factory/stock fluids and parts?
These are the changes I was thinking to doing (not all of them immediate) :
1) LED conversion of interior, puddle, license and reverse lights
2) Nokya Cosmic White highs and fogs with the plug and play harness
3) Mobil 1 EP synth 5W20 with Mobil 1 oil filter
4) Purolator air, cabin air and fuel filters
5) ATE Super Blue brake fluid, Mobil 1 MERC V synth ATF
6) SCT X3 Flash (can dealers tell even if you revert to stock before services?)
7) NAPA LEGEND Battery (Group 65 - 825CCA)
8) Alternate tire sizes (215/55/R17 for winters. I guess 245/45/R17s are fine since they are Lincoln approved alternate size)
9) 20x Chrysler Sebring lugs
10) Powder coating calipers
11) RotorPros brake package (slotted/drilled rotors, pads, SS brake lines)
12) Changing out the exhaust tips to better fill up the cutouts
Also how picky are they about crossing-Ts and dotting-Is as far as the scheduled maintenance guide goes? Does it need to be performed by a dealer / Ford certified mechanic?
