Changed degas bottle and upper rad. hose with in the last few years and when the cross over tube developed a leak I decided to change everything, including the down tube, water pump,& lower hose. The Harmonic Balancer has been wobbling & whining for a year since some trans work. So I got a used one and installed at the same time. I used the starter to break H/B center bolt.. (Breaker Bar against the Frame and crank the starter) it broke lose with a fast hit of the starter but with a loud crack, and the bolt came out the rest of the way by hand. Removed H/B with a puller, that all looks good with no more wobble.
Yes I had Intake off.. I scoped cylinders on passenger side so far nothing..I'm onto the other side now.. I'll let you know.
It kinda sound like the U tube Videos of Linc. Ls cracked flex plate.
It sounds like its coming from the back of the motor, but I can't pin point it, sounds the same on top as it does under the car.
Any other ideas or same experiences ?
Thanks Dan
Thanks Dan
