emissions test fast responce PLEASE
imnot2g4u
central nj
whats up guys just got my markviii the other day and the inspection sticker is due i was wondering since its a 93 do they do the tail pipe tester or is there the plug that newr cars have where they jus plug in a computer, i'm also in nj,,, also my check air ride warning comes on after a few minutes would that cause me to fail? thanks alot guys fast responce needed
I don't know how they do it in jersey but I have never heard of just checking the computer on pre 96(pre OBDII) cars. I would say your gonna be on the rollers. Air ride message shouldn't make any difference
The On-Board Diagnostic Test
The On-board Diagnostic (ODB) test reads a computer system in your vehicle to identify engine-related problems that may result in increased emissions of harmful pollutants. If you maintain your vehicle when you are alerted by your OBD system, you can help improve the state's air quality. (For models earlier than 1996, New Jersey will continue to use the earlier tailpipe-emissions tests during inspection.)
The OBD system monitors your vehicle at all times, even when it is not being tested. If it detects something that might cause your vehicle to emit excessive harmful pollutants, the "Check Engine" light will illuminate on your dashboard. This could indicate a simple problem, such as a faulty spark plug that should be replaced before it creates a more serious problem, such as a damaged catalytic converter.
i dont run any CEL's but my check air ride comes on after a few minutes, does anyone know if this would be reason to fail?
In RI they do the safety and emissions inspection. Air ride wouldn't fall under emissions but it may under safety. Needless to say I know a Mark owner who has the air ride message and he still passed. I wouldn't worry too much
