KPM
I'm going to have my Eibach spring kit inatalled on Wensday.
Read the instructions and have a question for those of you that have installed them already.
The instruction sheet has a line drawing that shows the bump-stop.
It shows that you are to trim the front and back bump-stops by 25 mm.
I assume this means you are to use the stock bump-stop that has been shortened by 25 mm, and not to trim 25 mm off and use the 25 mm piece.
Is this correct ?
Is this correct ?
