DTC 401 EGR Flow Insuff. Need Help
blairrf
Sayville
2000 LS V6
I can't get rid of this code, and I'm starting to think its a vacuum problem.
I replaced the EGR Valve and the EGR vacuum regulating solenoid, so I know the problem isn't either of those units.
The EGR tube wasn't gummed up or anything, but I did clean the little residue that had formed where the EGR valve mounts.
Has anyone had this problem? Any ideas?
go to a dealership (i know i know, everyone hates dealers) and ask for a DPFE sensor, it looks at exhaust back psi to see if the egr is opening up, only prob is a little exhaust flows through it and the condensation causes the sensor to go bad. it should be around $50 and its a 3 second job, lets see if i can find a diagram..........
wow i stand corrected! apparently Lincoln hates the ls v6 wow this thing is buried
Differential Pressure Feedback EGR—3.0L
Removal and Installation
Remove the cowl vent screen. For additional information, refer to Section 501-02.
Remove the seven bolts and position the cross vehicle support out of the way.
Remove the nut and the throttle cable bracket.
Remove the differential pressure feedback EGR.
Disconnect the electrical connector.
Disconnect the hoses.
Remove the bolts and the differential pressure feedback EGR.
To install, reverse the removal procedure.
damn pics dont come up, well when you go to the dealer, just tell them what your car is and that its the "bolt on style" DPFE, and might as well get the hoses while your there, doesnt sound fun and i would recommend replacing them now. you might be able to sneak in there and change it without pulling the cowl (thing under your wiper arms) its a plastic rectangle with 2 hoses running out the bottom and a gray 3 pin oval connector running out the side, some older ones were metal but same shape and are replaced with the newer plastic style. ford has SSM's (Special Service Messages) out for codes po401, po402, po403 i dont remember how high they go, but any egr flow code ford says to replace the DPFE first! i only saw 1 that the sensor didnt fix, and it was because a mouse ate through the wire elsewhere in the harness
yea that thing is buried...I have to pull the cross brace to get at it. Ordered the part a few days ago, should have just ordered that friggin thing first, but I was going with the path of least resistance.
