driveshaft u-joints
98LSC32V
Bay Area
There is play in the driveshaft ujoints on the 93 Mark VIII. I can hear a vibration under certain high load situations coming from that area. If I go to a driveshaft shop, how much should I expect to pay for this job?
why would u need to go to a driveshaft shop? Any experienced mechanic should be able to handle it no prob.
this is a very easy job with a U-joint press
looks like a big C clamp
If your are driving to the shop you will also be
paying for them to drop your gas tank
but if you took in just the shaft it would be way cheaper
like around $40 plus parts
