DragonDesign
The title says it all. I went to open my door to get out of the car the other day, and no dice. The handle pulls back with normal resistance and everything normal, only it won't unhook the latch. I looked at the assembly on the side of the door and this is what i see:
the latch is 2-stage, so when you push the thing down it'll click once and then again when you keep pushing. When you pull the handle it pulls back a little engaging piece so everything will pop back up into place and the door will open. Mine doesn't seem to pull down far enough and it won't let the spring pop the piece back into place.
Here's the wierd part, every once and a while the latch will work just fine as if nothing is wrong, then other times, I have to put the key back in, roll down the window, and reach out like an idiot to open the door from the outside. Anybody else have this problem, or have a solution? i'll lube up the handle, but i dont know if that will do it.
